Here are the responses I have received to date:
We have here early in our Windchill experience. It has happened when users shared the same computer but logged on to Windchill with different accounts which used the same local cache. This may not be happening for you, but this was our experience.
Could you try it with M210?
It could be a corrupted cache, I’d make sure everything is uploaded from all the workspaces and move/delete the local cache and then startup ProE again. Every time you connect to an existing workspace, it should download from the server side workspace to recreate the local workspace. (can take awhile with a large workspaces)
Some things you can try:
- make sure trail files are being written locally.
- disable workspace frames.
Let us know if these work for you or if you have other solutions. Same problem here on 9.1 m030.
There have been cases where the user access the same cache from two sessions of ProE. That can cause a corruption.
Virus checker program can be accessing the cache at the same time as the user. That can cause a corruption.
Two users accessing the same cache can cause an issue. Say you have a business admin account and a design account. If you access the cache with both users you can cause corruption.
I tell my users to access their business admin accounts from the web browser not the embedded browser.
