Environment:
Pro/I 3.4, M050; Sun/UNIX Dataserver; Windows XP-Pro,SP2 Clients (Dell P6x0 & M90/M6300 laptops)
Wildfire 3, M140
Description of Problem:
This scenario doesn't happen all the time; but it is intermittent to virtually every user we have. The Pro/I & Pro/E interaction as described belowwill work fine for several days, then all of a sudden you get a single (or sometimes 2-3) launch(s) where the behavior is as described here.
User launches Pro/I from Desktop shortcut and logs into Pro/I (There is NO separate shortcut for Wildfire; ALL entry is via the Pro/I launch shortcut)
Workspace (menu pick) -> XYZ and opens selected W/S
Select a Pro/E file (part, assembly, etc makes no difference); Right-click Open. Same thing happens ifyou Select object in W/S, Object, Open sequence from the top menu.
Pro/E launches (splash screen, Pro/E window comes up, etc) then Pro/I launches AGAIN presenting the user with another Login box and Pro/I Main Menu window.
So far PTC has given me a bunch of irrelevant junk that misses the mark by a mile! Anyone have any ideas about what might be causing this?
Thanks in advance for any assistance.
~jim
