Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Mike, Thanks for the response. I had that error with the ildataloader FT command and made the adjustments that you suggested. However; my problem occurs during the ildataload PartResume command which is later in the migration process. I was instructed by PTC NOT to use the WTPart creation of the Pro/INTRALINK Data Migrator. PTC has been suggesting to customers (for the last year or so without updating the Data Migrator documentation) to use the WTPart creation tool within the installation of Windchill PDMLink itself. This is documented in Appendix C of the Windchill Upgrade Guide that is available in the Reference Document section on their website.
PATRICK S WILLIAMS Information Technology Mechanical Engr Solutions Missile Systems Raytheon Company
This message contains information that may be confidential and privileged. Unless you are the addressee (or authorized to receive mail for the addressee), you should not use, copy or disclose to anyone this message or any information contained in this message. If you have received this message in error, please so advise the sender by reply e-mail and delete this message. Thank you for your cooperation.
