Problem Report
jlittle
8-Gravel
Problem Report
Trying to generate a Problem Report associated with a WTDocument, but cannot get the document objectID. Here is the snippet of code:
String sParent = "wt.doc.WTDocument:500463854";
wt.doc.WTDocument wtdoc = null;
ReferenceFactory rf = new ReferenceFactory();
WTReference ref = rf.getReference(sParent);
wtdoc = (wt.doc.WTDocument)ref.getObject();
The last line is not working. I get no error, but nothing happens either. Any help would be appreciated. Windchill 10.0 M040.
James Little
SimonHeath
(To:jlittle)
Code seems ok, wrap a main around it and run it from a command line. Use a Windchill shell to run it. You will get some better feedback an exception or something.
Simon
Object Identifier should have prefix of OR: or VR:
