Does windchill10.1 has capbility to track Product Structure ?
Whenever the changes made to the Product Structure is it possible to create the snapshot of that particular Product Stricture I am looking for tracking Product Structure based the Revision sequence.
For Example:
Assume Product Structure A.1. once I update the one or few components of the product stricture is it possible to create Product Structure A.2 to keep track of the changes I made.
Please let me know your thoughts on this.
Thank You,
Raghu Mavinahalli.
Hi Raghu,
Not sure if you tried using the baselines. An excerpt from the WHC 10.1
A managed baseline is essentially a snapshot of an object at a specific point in time. You can create a baseline in the context of a product or a library.
Once you have created a baseline, you can add and remove objects and documents that reflect the product structure. Business information associated with the objects and documents is also recorded.
refer the WHC link for more details.
~Syed
Syed:
Thanks for the reply, your answer is giving me the lead to the solution. few more questions on Baseline
1. Is it possible to add User defined attributes to Baseline ?
2. Does Baseline has revision sequence associated with it?
Thank You,
Raghu Mavinahalli.
Windchill is a powerfull tool for managing Product Configuration :
Baselines are one of these features.
Promotion request have a combined baseline and lifecycle state change capability
These features snapshot a particuliar iterations of your parts and BOMs
But Configuration Management deal mainly with Change Managment and effectivity management. You can use dated effectivity , or use a Product End Item as Config Item (lot, serial number ...). In this case, you will track Versions of your parts.
regards
Greg: Thanks for the reply, your answer is giving me the lead to the solution. i really appreciate your time.
Raghu.
Raghu,
Windchill has very broad and deep capabilities to track a products configuration and maturation over time.
Starting with the product structure / CAD structure and revisions thereof, there are many ways depending upon the needs and use cases to track and manage the configuration.
These include -
User wants | Configuration Specification | Description |
To find latest designs | Latest | Expand the structure using the most recently created versions of a selected View and Life Cycle State. Available for part and CAD document structures. |
To get the design from a specific event in time | Baseline | Expand the structure using versions captured in a previously created baseline. Available for part and CAD document structures. |
To see the configuration of a product based upon serial number or lot | Unit Effectivity | Expand the part structure using part versions assigned a specified serial number, lot number, or lot/serial number effectivity. Available for part structures only. |
To see the configuration of a product based upon date | Date Effectivity | Expand the part structure using part versions assigned a specified date, or date and time effectivity. Available for part structures only. |
To Get the data related to a promotion request | Promotion Request | Expand the structure using versions referenced by a specified promotion request. Available for part and CAD document structures. |
To get back the CAD data that the user had successfully regenerated and checked in | As Stored | Expand a CAD document structure according to a baseline automatically created when the CAD model is stored. Available for CAD document structures only. |
More detail can be found in the Help section on Change and Configuration Management:
http://www.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=CCMOviewIntroduction&action=show
To answer your question above - Baselines support typing and soft attributes
