Publishing - $ERROR$ Problem creating directory ftp : xx. Do not have write access
davehaigh
Having issues with FTP and publishing.
Publish Monitor says
TomU
(To:davehaigh)
Take a look at these two articles:
davehaigh
(To:davehaigh)
We just have the Creo adapter, but I have it setup for production, dev, and QA servers. One worker defined on each.
This worked fine in 9.1. The worker on each server pointed to its own folder.
I suppose I could set up unique virtual folders in the FTP site for each server also. Right now I have it set so all use the same folder.
Right now I'm just trying to get one server going.
[cid:image002.png@01D06B8C.D9D67B50]
CS33760 mentions running the service as Local Domain Admin. Very few folks here have those rights.
Plus we are https, which requires a real user run the service. This all worked fine in 9.1. I could have a typo someplace, who knows.
[cid:image003.png@01D06B8C.D9D67B50]
We are using FTP because, with all the security restrictions we live under, an open share becomes a problem.
Besides, ftp just seemed a more robust method. I was always having issues with the shared folder method.
David Haigh
