Publishing (or exporting a file) from Winchill 8?
ptc-1047216
Hi all,
I've been reliably informed that it is possible to publish (export) a file from Windchill 8 to a predefined location by using a "Workflow Robot". Has anyone here used this type of robot or has an example workflow that does this that they'd like to share?
Many thanks,
5 REPLIES 5
yes you can do that with java expression. Are you java programmer?
Unfortunatey, No, I'm not a java programmer (which is quite a handicap when it comes to trying to administer WC!).
It is problem for you write java expression whitch save file on disk?
I know nothing about java, so I would be unable to write it myself. But if some kind soul were to provide some example code for me to test, I could load it into to my test environment to play with.
Many thanks.
It not simple play with java)), because exists such aspects:
iteration, version, access, content type and other. You must find windchill/java programmer.
