Query-object search results size has exceeded the limit but the result size is less then the limit
rzemmali
I have a Windchill query-object which is returning the exception size has exceeded the limit of 200000. I updated the limit to 400000 then I got the result which strangely counts less then 200000.
Then I tryed to add paging to the query but got this exception:
Exception message:
com.ptc.core.command.common.CommandException: (wt.pom.pomResource/22) wt.pds.PartialResultException: Search results size has exceeded the limit set by the System Administrator.
Nested exception is: (wt.pom.pomResource/22) wt.pds.PartialResultException: Search results size has exceeded the limit set by the System Administrator.
Could you please help?
Thanks in advance.
There are several query limit properties and we don't know which ones are used by an Info*Engine query.  You can log a call with PTC Tech Supt but I would start by searching the PTC knowledge base on the more unique key words in your error: "wt.pom.pomResource/22" and "wt.pds.PartialResultException".
https://www.ptc.com/en/support/article?n=CS301334
https://www.ptc.com/en/support/article?n=CS26116
https://www.ptc.com/en/support/article?n=CS54402
