Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
I would like to know if anybody has any experience with the following technology setup.
We are exploring the possibility of moving our WC system to our corporate headquarters several thousand miles away. We know that the download of large models and assemblies would be quite inefficient over the WAN, especially the small band width we have with headquarters. We know that we could probably get around that with vault replication at our end.
But here is what is being proposed by corporate IT:
Run WC on a server farm at their location Run WF4 on a set of blade servers at their location so that downloads will only be from the server to the local blade. We access these blades with some sort of HP remote software of a Citrix like client. So our workstations here would be come "Dumb Terminals" to display the images coming from the blades.
Has anyone operated Pro/E connected to WC in this way ? We have no idea how the graphic performance of WF4 would react to this arrangement.
This e-mail (including any attachments) is confidential and may be legally privileged. If you are not an intended recipient or an authorized representative of an intended recipient, you are prohibited from using, copying or distributing the information in this e-mail or its attachments. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete all copies of this message and any attachments. Thank you.
We have implemented RGS here (the Citrix like client) to speed up the performance of Pro/INTRALINK 3.X which helps greatly. However the user of Wildfire is diminished a bit. You will notice a half second or more latency of your clicks. Why isn't the WC technology good enough to have WF loaded locally?
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
If you have a large, complex Pro/ENGINEER session running on a machine thousands of miles away, what will your graphics performance be? I suspect debilitating to the Pro/E session!
With Windchill 9.1, you could have your file stores in California, and the WC instance thousands of miles away, and not pay the WAN penalty for either graphics nor data transfer.
It sounds like IT is trying to cut costs on their end, and let Engineering pay the premium!
