I mistakenly added a vault to the wrong file cluster. Is there a way to remove it? I set it to Read Only and am currently trying to delete the vault (this is a replication only vault) in proimgr but I am receiving an error that the vault is in use. Has anyone done this successfully? I am running 3.4 M040. Thanks in advanced.
Patrick Williams | Sr. Application Engineer | Engineering Systems | Steelcase Inc. | 616.698.4078
