Render String Attribute in Task Form Template
hbock
I have a read-only String attribute that holds some comments as text, that is aggregated during operation of tasks within the workflow. Every line is coded with eol (line.separator) at the end.
When I display the field in the details view (More Attributes Info Page Layout) or in the edit view (Edit Layout) then the contents is correctly rendered (multiple lines of text)
line 1
line 2
line 3
But when I display the attribute in the Task Form in the Task Variables section (visible, read-only, resettable), then the text is rendered to
line 1<BR>line 2<BR>line 3<BR>
I've tried both the default Task Form Templates for 'Native' and 'JSP' which are documented to render to HTML.
Both have the same behaviour.
Where am I wrong? Your help is appreciated!
Harald
0 REPLIES 0
