Rendered Creo file doesn't show any content when opened in Creo View
ptc-5378361
Some legacy Parts when imported into Windchill and rendered via the Creo view worker do not display correctly in Creoview.
PDMLink Version is 10.1 datecode M040.
Creo View Adapters (MCAD,ECAD) vers 2.0 datecode M040
The legacy parts were created in Wildfire 5.
The WVS rendering job appears to complete OK according to the logs.
When the file opens in Creo View 2.0 the meta data appears but the visualisation image is not seen.
I assume this is some subtlety in how the part was modeled that is different as 99% of the parts and assemblys render OK.
Any advice on what to look for in terms of rendering settings and possible causes would be appreciated.
Cheers,
Nick.
Please test proepublish.bat to Interactive Publishing.
This is descrived at PTC Creo View MCAD Adapters X.0 Installation and Configuration Guide pdf document.
This way you can test if Worker in indeed ouputing a correct visualization.
If not, so, there is a problem with Creo and its configs...
Thanks I'll give that a try.
