Hi ,
I have created a report in WBR using the Query Builder approach. I have a prompt page on the report which provides the input paramaters based on which the report is to be run.
When I run the report in Report studio by selecting the input parameters and click on finish in the prompt page, the first time it does not fetch data. However on the second run the data is retrieved and displayed on the report page.
I tired disabling caching by setting the queryReuse parameter to zero in the CQEConfig.xml file. I have also tried setting Report->Set Properties->General Tab: setting "Run History" to zero and "Report output versions" to zero and the Report->Set Properties->Report Tab: Setting the default action as "Run the Report"
However these changes did not help in resolving the issue, Is there any other configuration to be done in the Report studio is disable this occurence.
Pradeep
