Review Promotion Request - Conditional
Cosmo
Hi All,
I believe we're using the OOTB Promotion Request Review workflow.
In this workflow, there is a "Review Promotion Request" task. We would like to setup a conditional that checks the target state of the object is being promoted. If this promoted state is going to be "obsolete," then we'd rather skip this review task.
Does anyone know how the find the state of the object being promoted?
Thanks in advance.
Mike -
MikeLockwood
22-Sapphire I
(To:Cosmo)
Better to set up a different workflow process that always gets used for target state = obsolete. The UI is not all that intuitive but works once you get the hang of it. Note: This is missing in 9.0, added back in 9.1.
[cid:image001.png@01CBD8BC.9026BC20]
[cid:image002.png@01CBD8BC.9026BC20]
[cid:image003.png@01CBD8BC.9026BC20]
dwilliams
(To:Cosmo)
You could use the following expression to get the target state.
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
//maturityState is a process String variable
maturityState = pn.getMaturityState().toString();
