SOAP client errors
ptc-4551031
SOAP client errors
Hi Guys!
I am trying to interract with Windchill using SOAP by implementing some own WCF based client app and have the following issue:
1. I add service refference to the project for "com.ptc.windchill.ws".
2. Use generated classes to communicate with Windchill:
//Create client via the corresponding credentials
EServiceClient client = new EServiceClient();
client.ClientCredentials.UserName.UserName = "some_username";
client.ClientCredentials.UserName.Password = "some_password";
//Here we receive correct documents collection ( it works fine here and returns correct result)
var docs = client.Query("wt.doc.WTDocument", "name = 'some_doc_name'", null, null);
//This code line fails with exception : "Either the "OBJECT_REF" parameter or the "TYPE" and "WHERE" parameters must be provided."
var infos = client.GetVersionHistory(new string[] { docs[0].ufid }, null);
So, the question : Why does it happen? I indicate really correct ufid for the really existing object on the server but don't receive correct result here.
Am I doing something wrong? Please, help...
Thanks in Advance
0 REPLIES 0
