SUMMARY - Multiple instances Intralink 3.4 problem
Regular Member
Only one reply (thanks Brian), but I was able to fix it myself.
So the following command bails out just after creating the second DB.
> ./install_ilink ALL iltf INTRALINK
All I needed to do was to run the following steps myself manually:
> ./install_ilink SCHEMA iltf english INTRALINK
> ./install_ilink SYSPOOL iltf bemosun03 7777 /data3/ptc/vaultstf
english INTRALINK
> ./install_ilink VALIDATION iltf INTRALINK
Kind regards,
Olaf Corten
