Safe way to remove Windchill Business Report before rehost and upgrade
rbadin
We have a Windchill 10.2 M010 CPS 04 with Windchill Business Report installed and configured in a separeted server, along with SQL server on a third server.
Which is the best way to remove all the references to Cognos on this installation and shutdown this server to restore it on a new server then upgrade to Windchill 11 (or 10.2 M030) without cognos?
LoriSood
23-Emerald I
(To:rbadin)
Once a module has been installed in Windchill there is not usually a good way to uninstall/remove it from the Windchill configuration. You can disable Windchill Business Reporting. See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS48780
