Hi!
Anybody know which arguments should I set to the setIteration(String arg) method? And may be you know an example of ObjectRefs() method argument.
Thanks!
HI Anton,
Not sure if this is of any help, I just found a reference for SearchCriteriaInfo.setIteration(); in SearchQueryHelper.getIteration(...)
paramString1 = "LATEST";
paramSearchCriteriaInfo.setIteration(paramString1);
I havent used this personally.
I am not quiet sure if I understood the second part of your question - 'And may be you know an example of ObjectRefs() method argument.' What API do you intend to use this in?
-Malavika.
Hi Malavika!
I want to search only documents that have the link with the part. I think that I can set this option throughs method...
You can use reference factory to find reference of the object :
Iterator localIterator = null;
Object localObject1;
if (paramIterator != null) {
localObject1 = this.searchInfo.getCriteriaInfo();
ArrayList localArrayList = new ArrayList();
while (paramIterator.hasNext())
Object localObject2 = ((SearchResultItem)paramIterator.next()).getItem();
if ((localObject2 instanceof WTReference)) {
String str = referenceFactory.getReferenceString((WTReference)localObject2);
localArrayList.add(str);
else {
localArrayList.add((String)localObject2);
try
((SearchCriteriaInfo)localObject1).setObjectRefs((String[])localArrayList.toArray(new String[0]));
Not sure if this is what you were looking for.
On second thoughts, do you think SearchCriteiraInfo.setWhereClause(...) can help you find only documents that have the link with the part ?
I am not sure, that I can do it with the SearchCriteiraInfo.setWhereClause(...). I am finding how I can do it
. Thanks for reply!
Ahh... Let me know when you've figured out a way. ![]()
