Searching for Simplified Reps in Windchill
ptc-809592
Is it in annyway possible to search in windchill and include names of simplified reps in that search?
Let's say i know the name of the rep but i want to find the assy it's in...
It's more complicated than that but I'll spare you the BS.
yes Joris, you can easily write your search query to get the wt.representation.Representation first and then you can get the Representable from it(the object for which this Rep is) type cast it, you will get the CadDoc(or any object) and then get the assembly from the EPMDocument. I hope I understood your concern's and replaying back with the appropriate solution,
wt.representation.Representation.getRepresentable()---->Gives you the base object.
