Dear Users,
I am trying to capture the State-change event from the Syn Robot (via Object Type & Event tab). While performing the state chage from UI , it terminates the WFProcess with Syn Robt. The reson being , the set-state wizard (UI) had an option to terminate wfprocess which is explicitly selected .
Can you share your toughts if there a way to remove the default selection ? Or is there a reson for having it ?
Sriram Rammohan
Hi Sriram,
You can select the process and say Continue rather than default selection Terminate. See attached screen shot
Hope this helps!!!!
Karan
Thanks Karan , It helped out me.
Sriram Rammohan
