Setting Change Management workflow
BenLoosli
Under Preferences for Promotion Request is a setting for which promotion request workflow you want to use.
There is no similar setting for the Change Management preferences of Change Request, Change Notice or Change Activity. How do you select which workflow do use with these processes? The OIR for these specifies a renamed OOTB workflow for all three, but when I create a new Change Request, the OOTB workflow is being kicked off.
If I have the modified CR workflow enabled, then I get an error about having no permission to run the workflow.
Am I correct in assuming that the software is defaulting to the OOTB workflow when the one in the OIR is not enabled?
Any help in pointing to any documentation on how this works would be appreciated.
I am running WC10m040 PDMLink.
Check the Lifecycles associated with each of your types (OIR), and check which Workflow those Lifecycles are using.
Also, OIR can be overridden with increased specificity - meaning Site level OIR's will be overridden by Org level OIRs will be overridden by a specific Product Context OIR.
Being inherently lazy, I prefer to manage OIR's at the Org level if at all possible
Don't know about a documentation pointer but we just set up our own clone of the OOTB workflow.
My understanding of the "chain of objects" is: A (Soft)Type points to a OIR which points to a LifeCycle which points to the Workflow.
So in short if you jump into the chain at the OIR you start by introducing your own modified LifeCycle which in turn points to your own Workflow
LoriSood
23-Emerald I
(To:kpritchard)
Keir is right. Check the Workflow tab of the lifecycle associated with the change object. It will have a worflow template specified.
