Version: Windchill 12.0
Use Case: I want to add a column with the released/assigned ECN in the search windows results and in the active workspace.
Description:
I am working with windchill 12.0.2.15 for releasing using ECN a lot of parts for production and it will be useful if in the search result window and in the active workspace to have a column with the ECN number released or assigned next to the number and name columns.
Right now, the only information to identify that a number is assigned to an ECN is a red triangle in the search result window.
I tried to add all the columns available, and none of them are with an ECN info.
Thank you,
I think this can be done with an alias attribute similar to this:
https://www.ptc.com/en/support/article/CS411743?source=search
Hi @AndreiH,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
