Simple (I think) question on where clauses - sent too soon
avillanueva
23-Emerald I
I've been through the guides, can't seem to find an example of where
clause other than single clause. I am using dca-Query.xml and want to
find WTParts by a number, view and that are the latest version. Here is
my code:
task.addParam("search_type", "wt.part.WTPart"); //should get WTPart
task.addParam("where",
"number="+topLevelWTPart+",isLatestVersion="+"true"); //WTPart number
Task seems to indicate that where can have multiple entries and is comma
delimited.
<ie:param name="type" data="${@FORM[]search_type[]}"/">
<ie:param name="where" data="${@FORM[]where[*]}"&lt;br"/>delim="," default="()"/>
Does someone have an example of multiple where expressions? What about
AND and OR expressions?
I looked up the logical names and it does show that isLatestVersion is
available but returned following message.
com.infoengine.util.IEException:
com.ptc.core.meta.common.impl.LogicalAttributeFormatException: Unable to
find logical a
ttribute: "isLatestVer.id with context: "WCTYPE|wt.part.WTPart"
Nested exception is:
find logical attribute: "i
sLatestVer.id with context: "WCTYPE|wt.part.WTPart"; nested exception
is: com.ptc.core.command.common.CommandException:
to find logical attribute: "isLatestVer.id with c
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown
Source)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at
com.infoengine.procunit.IEExceptionUtil.checkCollectionForErrors(IEExcep
tionUtil.java:137)
at
tionUtil.java:34)
at com.infoengine.SAK.Task.executeTaskRemotely(Task.java:2069)
at com.infoengine.SAK.Task.invoke(Task.java:1713)
Thanks in advance for any pointers.
5 REPLIES 5
One piece solved, it is a comma separator.
"number="+topLevelWTPart+",view.id="+"wt.view.View:1447");
Also needed to provide ID for view in that format.
Hi Antonio,
Try using
& for AND
| for OR
Murugesh
On Fri, Sep 23, 2011 at 10:07 PM, Villanueva, Antonio <
-> wrote:
> One piece solved, it is a comma separator.****
> task.addParam("where", "number="+topLevelWTPart+",view.id
> ="+"wt.view.View:1447");****
> Also needed to provide ID for view in that format.****
RTFM - 3-3 of WC Adapter Guide for Where clause syntax
Antonio, did you ever figure out the isLatestVersion issue in the where clause? I'm able to use it as an attribute to return, but not in my Where clause.
My error is identical to what you have in my infoengine task.
<%@page language="java" session="false"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Get-Properties" type="MGT">
<ie:param name="AUTHORIZATION" data="${@SERVER[]authorization[]}"/">
<ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/">
<ie:param name="GROUP_OUT" data="properties"/">
</ie:webject>
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="${properties[0]wt.federation.ie.VMName[0]}" valueseparator=";" delim=";"/>
<ie:param name="ATTRIBUTE" data="obid,number,isLatestVersion,name,lifeCycleTemplate.name,containerName,iterationInfo.latest" delim=","/">
<ie:param name="TYPE" data="wt.part.WTPart"/">
<ie:param name="WHERE" data="isLatestVersion.id=true"/">
<ie:param name="GROUP_OUT" data="myQuery"/">
</ie:webject>
Thx
Steve D.
In Reply to Antonio Villanueva:
my code:
delimited.
find logical a
Method)
Source)
at
Source)
at
tionUtil.java:137)
at
tionUtil.java:34)
Steve,
<ie:param name="ATTRIBUTE"&lt;br"/>data="obid,number,isLatestVersion.id,name,lifeCycleTemplate.name,containerNa
me,iterationInfo.latest" delim=","/>
Does that make a difference at all, adding the .id in attribute field?
isLatestVer.id is different from what you show here.
If not, did you check to see if this is indeed a logical attribute and not a
computed? It may only be trying to look at what is in LogicalAttributes.xml
or a persisted attribute. A search objects webject might be quicker? If not
you can add a custom logical attribute in the xml file for version sort id
to persistable as highest against that master?
- Dave
