The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Pros:
We have been having an internal debate for some time on part numbering. We currently number manually from spreadsheets using prefix+sequential number+suffix for parts and subassemblies as well as smart part numbering for high level assemblies.
Some like the status quo.Some would like dumb numbers across the board. Some would like a middle ground where prefixes are maintained andthe number is generated from Windchill.
Autonumbering would be great time and error saver especially for Save As operations on large assemblies(which we do daily). Unfortunately, the Windchill autonumbering is not flexible enough nor consistent enough OOTB to satisfy and ERP generated numbers are not an option. We would like to get everybody working consistently and save them some pain if possible, but that seems unlikely without a lot of customization.
My question is "how do you manage part number assignment at your company?" Manually? Autonumbering? Special App?"do you generate smart or dumb numbers?" and "have you maintained your legacy numbering or gone to a new scheme?"
Thanks,John Frankovich
The GSI Group
Hugo-
If possible, could you elaborate on why you would not align name and number for WTParts if you could do it over again? My company is close to implementing WTParts, but fromthis point(prior to actuallyusing WTParts) it is difficult to know the ramifications of the decisions yet to be made. Thanks,
-Randy
When we first installed Windchill, we bulk loaded all of the existing part numbers into the system as-is. There is no business value in converting existing numbers to a new format, and the costs from the standpoint of drawing updates, distribution channels, BOMs, MRP systems, etc would be astronomical.
That said, we implemented a new, dumb, iterative numbering scheme for all WTPart objects created going forward. One reason for this was that we had different sites using different numbering systems, and we had some conflicts (p/n 123456 at one site was a valve, p/n 123456 at another site was a seal). Having everyone use the same system and pull from the same pool of numbers is a huge benefit. Also, in our eyes, the sole purpose of a part number is to provide a unique identifier for a part, that's it. Any information you get from prefixes or smart systems can often be better managed using other tools.
Our exception to this rule is for our End Items. We allow custom naming for these. Reason being that they are customer facing, and while we don't mind changing things around internally, we didn't want to suddenly change the structure of the part numbers our customers were ordering.
One interesting possibility is the use of subtypes. In 7.0 we couldn't use part subtypes, but you can in 9.1. If you really need to classify your parts, do it using subtypes or IBAs, not smart numbers. We have yet to apply this for parts but did something like this for documents... same problem with multiple smart numbering systems for documents. Problem was that different sites used different smart systems, and if you don't know the smart system for the site whose document you are viewing, there might as well be no smart system at all.
So we now use dumb, iterative document numbers, but we use a combination of document subtypes and IBAs to categorize them. We probably have somewhere in ther range of 100 different document types. That would be a long list to select from, so we broke it into two levels. When you create a document, you select one of 7 subtypes such as "Report", "Procedure", "Protocol", "Specification", etc. Then when you are entering attributes, you select a value from a Subtype IBA which has differentvalues depending on the document subtype selected. So if I chose a report, I could select an engineering report, lab report, etc., or if I chose a specification I could select requirement specification, functional specification, etc. By using this approach instead of smart numbers, you 1) have the ability to search and filter your documents, 2) have a system that EVERYONE understands.
Bob PriestEngineering Manager
STERIS Corporation
We sub-typed parts, and also made a difference betweenpurchased parts which are in libraries from designed parts which are in products. We defined a prefix for each subtype, a prefix foreach library,and generated autonumber using that prefix depending onthe type or/and location of each part (all library parts have a 2x prefix, all product parts a 1x prefix).
Parts inherited from our previous system kept their numbers, which also contained a prefix that preventedcollisions with new part numbers. We made an exception for product documents whose numbers are allocatedin another system, andlet people enter the numbers from that system. We also use autonumbering for mechanical parts, the numbers are allocated in proE, with the appropriate prefix. Purchased Mechanical Parts are in a library, so theyhave a different prefix than designed parts.
Vincent
