Has anybody noticed the sorting definition of the "UP" and "DOWN" arrows has switched between WC10 to WC10.1? See attached image which shows two WS tables for WC10 and WC10.1 with the arrows (sort descending/ascending) feature giving different results. The admins can change the default global views to make the correction for our transition. However, is there an option to repair all the unique user settings? This will be a disatisfier for all users with custom views.
Follow up to this issue and how we are resolving it since we are now in Production with WC10.1. After further diagnosis, the issue is associated with the "Modified Status" column only. Our solution was to change the sort rule for all applicable filters to be Descending instead of Ascending in the workspace tables. Not ideal because each user has to update their own personal created views.
