Standard Attribute Column Type for Hyperlink Soft Attribute
pwilliams-3
Hi Everyone,
I would like to create a soft attribute of type hyperlink on the WTPart but I don't know what the right data type is to give the AddColumns command. The attribute will reference another WTPart but not in the typical "uses" fashion. Would it be the Object Reference type?
The following column datatypes are supported:
* String
* Long
* Double
* Boolean
* Timestamp
* ObjectReference
* InlineBLOB
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image002.jpg@01CE2557.608DA0C0]
Mike,
Would it be possible to create the hyperlink to the master object to avoid getting "stuck"? Another possible alternative is to use the Alternates functionality.
[cid:image002.jpg@01CE255C.F143E2A0]
I want to identify when Part 123 is "Superceded By" Part 987. To accomplish this I think I have to use a combination of life cycle state and the Alternates functionality. Part 123 would be promoted to RELEASED_NOT_MAINTAINED (users should not use this object) and then add Part 987 as an alternate for Part 123.
[cid:image002.jpg@01CE2560.1580BE10]
I know there has been other discussion on this but it would be string not an object reference.
Sent from my Verizon Wireless 4G LTE Smartphone
Thanks everyone for the help, however with further discussion with my team we will use the Alternates functionality rather than a new attribute.
[cid:image001.jpg@01CE2564.F417C980]
