Strange issue with family table
ybhide
PDMLink 8.0 m030
WF 3.0 M200
Gurus,
Here is a strange sequence I just went thru. Any idea what PDM/Pro E is
acting up like this?
(I checked out generic to add instance to family table)
Enter object to checkout [NUT_COARSE.PRT]
Checkout succeeded.
Invalid value
(Here I added instance and validated)
Regenerating N_1_8 feature 1 out of 10 ......
Regenerating N_1_8 feature 10 out of 10 ...
Regeneration completed successfully.
Regenerate status output to file nut_coarse.tst
(Now when I tried to Auto check in - I have entire family table checked
out at this point)
Checkout failed. See Event Manager for details.
Modification of the object has been aborted.
wtws://PDMLINK/i-2415-2/nut_coarse.prt.1 could not be saved to the
workspace.
ModelCHECK is Processing NUT_COARSE.PRT
ModelCHECK - Process Complete.
NUT_COARSE could not be saved to the workspace.
(So tried to save it first)
NUT_COARSE has been saved.
(Now try to check-in again)
Cannot check in NUT_COARSE.PRT, because it is not checked out.
(OK.. how about trying to check it out since event manager is saying I
can not check it in because I do not have it checked out)
(Now event manager says it can not be checked out because it is not
checked in. SO trying to check in again..)
(So now I go to workspace and try to check it in. MIRACLE. It goes thru
with out a problem.. btw I only had coke during lunch..)
Started Upload of Documents.
Upload succeeded.
Started Check-in of Documents. Associated WT Parts will also be
checked in ...
Check-in Succeeded.
This email and any files transmitted with it are confidential and intended solely for the person(s) or entity to whom they are addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this email in error, please contact the sender and delete the material from any computer.
0 REPLIES 0
