Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We're planning a Pro/INTRALINK 3.4 M062 implementation on a pair of Sun Fire T2000's: One for the Data Server, one for File Server. Anyone else ever use these? Good idea, bad idea? Thanks for any insight, -- George Leonard, Space Systems/Loral T:650-852-5215 F:650-852-7170
