The System Admin Guide says that if you are using vaults you need to have fault tolerant storage because the database and file system (vault) backups won't be synchronised.
So does everyone out there have fault tolerant storage systems for both the database and vaults (i.e. you never have to restore either from a backup), or is there a backup technique or process that get’s around this issue?
(Currently WC 8.0 M40)
