To check whether there are approvers & reviewers selected befor a promotion is created
praseeth.moothe
I need to check whether the APPROVERS & REVIEWRS are selected before a promotion request is created. I am trying to write an event listener for this. I tried the PRE_STORE, POST_STORE, INSERT, PRE_INSERT events on promotionNotice object. But however, I am not able to get the members selected in the listener code. It is always retuning empty lists. Is there any other specific events on Promotion objects to listen to ?
5 REPLIES 5
Instead of event listener, have you thought about adding conditional robot (in promotion workflow) that checks for selected participant(s) for APPROVERS & REVIEWRS roles? Following post would help.
http://portal.ptcuser.org/p/fo/st/post=119216&anc=p119216#p119216
Hi Yogesh,
Having the check in conditional robot would mean that the workflow is
triggered. What I want to achieve is that till approvers, reviewers are
selected, it should not allow to create a promotion request. That is why I
went for listener.
Praseeth M
You can try with validators.
Use beforeVK call @create promotion action.xml
MKR
Thanks guys for the answers...I achieved this using a delegate class for
the wizard step. Turned out to be pretty easy.
Praseeth M
Hello Praseeth,
we have simillar requirement, can you please provide info how did you achieve this,  is it the code goes in postprocess delagte class.
any input is highly appreciated.
Sughosh
