Unable to invoke remote method using eclipse
aacciano-2
11-Garnet
I am running eclipse from my laptop while Windchill runs in the server.
Everything worked fine until I had to switch from HTTP to HTTPS.
Now when I run anything I get the following error:
Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
wt.method.AuthenticationException
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:810)
at wt.services.ServiceFactory$ClientInvocationHandler.invoke(ServiceFactory.java:349)
at com.sun.proxy.$Proxy0.refresh(Unknown Source)
Any suggestion how to fix it while have the server running on https?
I tried to install the certificate in the local keystore but the error is still there.
Thank you!
Hello Antonio,
I'm facing the same issue that you have reported. Did you get any fix for it ? if yes please let me know.
ChandraMouli Panduri
pselvaraj
3-Newcomer
(To:cmouli)
Did you get fix for it?
