Update attributes of a project (wt.proj mgmt.admin.Project 2).
afreitasribeiro
Hi, need to update attributes of a project.
The interface allows you to edit one at a time, but I like to do this lot, because I have several projects to upgrade.
I tried doing this via xml, but I have no success.
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
String typeFather = "wt.projmgmt.admin.Project2";
String typeChild = "net.odebrecht.PROJPO";
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="windchill" delim="!" valueSeparator="!" default="<%=com.infoengine.au.NamingService.getVMName()%>"/>
<ie:param name="GROUP_OUT" data="resultQuery"/>
<ie:param name="TYPE" data="<%=typeFather%>"/>
<ie:param name="WHERE" data="(number='*')"/>
<ie:param name="ATTRIBUTE" data="*"/>
</ie:webject>
com.infoengine.object.factory.Group obj = getGroup("resultQuery");
int quantidade = obj.getElementCount();
System.out.println("Quantidade de elementos no GRUPO: " + quantidade);
for(int x = 0; x < quantidade; x++){
if(tipoDoc.equalsIgnoreCase("WCTYPE|wt.projmgmt.admin.Project2|net.odebrecht.PROJPO")){
String tipoDoc = (String)obj.getAttributeValue(x,"class");
String number = (String)obj.getAttributeValue(x,"projectNumber");
String atributeprojetoAtual = (String)obj.getAttributeValue(x,"AUFO_CNTR_CODIGO");
String novoAtributoProjeto = (String)obj.getAttributeValue(x,"CNTR_CODIGO_PO_RFQ");
<ie:param name="GROUP_OUT" data="resultQueryChild"/>
<ie:param name="TYPE" data="<%=typeChild%>"/>
<ie:param name="WHERE" data="(number='<%=number%>')"/>
</ie:webject>
System.out.println("Tipo de Documento = "+tipoDoc);
System.out.println("Projeto Atual = "+atributeprojetoAtual);
if(atributeprojetoAtual !=null){
System.out.println("Indice:" + x);
System.out.println("Number: " + number);
System.out.println("Atribute projeto Atual: " + atributeprojetoAtual);
System.out.println("Novo Atributo Projeto: " + novoAtributoProjeto);
<!-- CheckOut-OBJECTS
<ie:webject name="CheckOut-Objects" type="ACT">
<ie:param name="GROUP_OUT" data="checkoutDocument"/>
<ie:param name="OBJECT_REF" data="$(resultQueryChild[0]obid[0])"/>
</ie:webject>
Update-OBJECTS
<ie:webject name="Update-Objects" type="ACT">
<ie:param name="FIELD" data="CNTR_CODIGO_PO_RFQ='<%=atributeprojetoAtual%>'"/>
<ie:param name="OBJECT_REF" data="$(checkoutDocumento[0]obid[0])"/>
<ie:param name="GROUP_OUT" data="resultUpdate"/>
</ie:webject>
CheckIn-OBJECTS
<ie:webject name="CheckIn-Objects" type="ACT">
<ie:param name="GROUP_OUT" data="checkinDocumento"/>
<ie:param name="OBJECT_REF" data="$(resultUpdate[0]obid[0])"/>
</ie:webject> -->
0 REPLIES 0
