Update some attribute with a XML Task
ptc-4715649
Hi everybody.
I'm trying to create a XML Task in Windchill to update an attribute in a Part.
This XML should receive the PLM code and the attribute, the ERP code, perform a check out, update the attribute, and do a check in.
I can do the check out / checkwithwebject, but the Update-Object webject keeps returning an error. The webject is as follows:
<ie:webject name="Update-Object" type="ACT">
<ie:param name="FIELD" data="&lt;a" href="mailto:codigo_erp=${@FORM[]CODERP[]}">codigo_erp=${@FORM[]CODERP[]}"/>
<ie:param name="GROUP_OUT" data="UpdtPart"/">
<ie:param name="INSTANCE" data="${properties[0]wt.federation.ie.VMName[0]}"/">
<ie:param name="MODIFICATION" data="REPLACE"/">
<ie:param name="OBJECT_REF" data="${checkout[0]obid[0]}"/">
</ie:webject>
The error I got is this:
<exception name="exception" type="Exception" status="-1">
<wc:message>java.lang.ClassNotFoundException: Nested exception is: java.lang.ClassNotFoundException; nested exception is: wt.util.WTException: java.lang.ClassNotFoundException: Nested exception is: java.lang.ClassNotFoundException</wc:message>
<wc:instance>
<hierarchy>com.infoengine.util.IEException</hierarchy>
<hierarchy>javax.servlet.jsp.JspException</hierarchy>
<hierarchy>java.lang.Exception</hierarchy>
<hierarchy>java.lang.Throwable</hierarchy>
<hierarchy>java.lang.Object</hierarchy>
</wc:instance>
TheObject Reference thatI'm passing is the obid of the Part I'm editing.
What's wrong with my webject?
Thanks in advance.
Renato Mádisson
Configuration Analyst at Mectron Odebrecht
I’ve discovered the problem. In the JNDI Adapter Guide the webject name is set as “Update-Object”, singular. The correct use is the plural: “Update-Object
Hello, Renato,
I will follow up on this and ensure that the documentation is updated.
Thankyou,
Jane
Jane Zupfer
VP, Enterprise Products Publications
T
E -
