Upgrade error executing a JavaMigratorDirective with className=wt.org.PopulateUserFullNameFields
chicosptckrak
Upgrading from Windchill 10.1 M050 to Windchill 11 M030. This task is failing when trying to configure JNDI enterprise adapter.
The nested exception, AuthentiationException is given below. How can I verify/specify the userid/password to the UpgradeManager?
After the first time providing this information during Gather Upgrade Properties phase, the UpgradeManager UI does not provide a way to verify/re-specify the values.
"Caused by: wt.util.WTException: Error in finding mapping key for "user.cn" in adapter : com.xxxx.hq.xxxpvmflexapp11.XXXADS
Nested exception is: com.infoengine.exception.adapter.IEAdapterException; nested exception is:
javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C09042F, comment: AcceptSecurityContext error, data 52e, v2580"
Thanks for help in advance.
Did you get it fixed?
