Using Process variables to set permissions on contents objects with Assigned Activity
kpritchard
Hi All,
End Goal is to enable front line Designers with Revise capability on objects contained in a Change Task at implementation. My thinking is to create process and activity variables and use these variables to set permission with the "Complete Change Activity" assigned activity.
My Javaspeak is not sufficient to interpret the JavaDoc and determine which Methods to call, or if this is even possible.
Any help, guidance or outright recalibration will be greatly appreciated.
Cheers,
Keir
0 REPLIES 0
