Using the bundled JAVA configuration option does not allow the applet to run
CHASEONHO
18-Opal
When you install PDMLINK, the JDK is installed as a bundle.
However, pages such as the vault configuration or the lifecycle configuration do not run because of security.
Therefore, we downloaded our latest JRE from www.java.com/en/download and filled out our PDMLINK address in the JAVA configuration security prompt.
(It did not work when writing the PDMLINK address to the bundled JAVA configuration security prompt.)
JAVE SE becomes subscription policy after 1 2019.
Could this be a problem when using PDMLINK?
Warm Regards,
SeonHo, Cha
0 REPLIES 0
