Variable Role - wt.project.Role
  • February 5, 2013
  • 0 replies
  • 648 views
In 10.0 M030 I am setting a wt.project.Role variable on a start transition for a task. The possilbe roles are on the a team template. When the tasks is assigned it is setting the role properly, but it is not setting the assignee as the user that is in the team role, instead it is setting the author of the PBO as the assignee. Any suggestions?
