Hi Everyone,
Can we check-in/check-out directly without using the WGM Connector. For example Third party CAD software is integrated with WGM, we'll see the Windchill ribbon in top using that tab to check-in into Windchill, but it's not directly going to Windchill right it's only save in workspace (WGM - Local Workspace) once again there only we can check-in into windchill directly. Can we break that directly check-in.
Thanks in Advance,
Amir
Not that I know of. Depending on your version of Windchill, newer licensing requires different licenses to even connect your CAD to Windchill.
Thank you for the replay Mr. Jbailey,
I have a WGM connector whenever I check in, it's only saved in WGM there we can check in into Windchill, right? I want to break that I have WGM but directly check in and check out through AutoCAD.
Amir
