WTPart Source attribute
avillanueva
23-Emerald I
Does anyone know if there is any special logic in the Source attribute
for Parts? I am sure this is controlled by a resource bundle and is
expandable. I am wondering about other modules like ESI and the
Sourcing modules if they depend on specific values.
Antonio Villanueva - Sr. Software Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Road, Danbury, CT 06804
Tel: +1 203 797 5682
antonio.villanueva@utas.utc.com www.utcaerospacesystems.com
CONFIDENTIALITY WARNING: This message may contain proprietary and/or
privileged information of UTC Aerospace Systems and its affiliated
companies. If you are not the intended recipient please 1) do not
disclose, copy, distribute or use this message or its contents, 2)
advise the sender by return e-mail, and 3) delete all copies (including
all attachments) from your computer. Your cooperation is greatly
appreciated.
For SUMA there are properties that can be modified to add any custom "Source" values to identify what values are Buy or Single Source
com.ptc.windchill.suma.oemPartMultiSource=buy
com.ptc.windchill.suma.oemPartSingleSource=singlesource
We had played around with adding some additional Source Values, and we saw no issues with it. In the end it didn't meet the business need so we removed them.
With ESI, you map they type to the corresponding ERP ID. Since we didn't proceed with adding any additional values, we didn't test the impact to ESI.
Source.make.*.*=1
Source.buy.*.*=2
Hope this helps,
Steve D.
