Webject Session/Transaction Question
MichaelWright
Hi All,
I am in the process of composing a webject to transfer attributes that have been defined in a workflow and place them in the attributes of the WTDocument. I have the concept working with the Checkout, Update, and Checkin, but am having issues surrounding the Start-Session and Start-Transaction. I received a template from a colleague and unfortunately that is all it is is a template and he doesn't know why I am receiving the error I am either. The Coding I am using is:
Start Session Webject
- Generates a new unique Session ID
<ie:webject name="Start-Session" type="ACT">
<ie:param name="INSTANCE" data="<%= instance %>"/>
</ie:webject>
Start Transaction Webject
- Creates a new transaction
<ie:webject name="Start-Transaction" type="ACT">
<ie:param name="SESSION_ID" data="$(session[]session_id[])"/>
</ie:webject>
Check Out Objects Webject
- Objects must be checked out first, in order to update their IBAs
<ie:webject name="CheckOut-Objects" type="ACT">
<ie:param name="TYPE" data="WCTYPE|wt.doc.WTDocument"/>
<ie:param name="WHERE" data="number=<%= docNumber %>"/>
<ie:param name="GROUP_OUT" data="checked_out"/>
</ie:webject>
Update Objects Webject
- Update the objects in the checked_out info engine group only
<ie:webject name="Update-Objects" type="ACT">
<ie:param name="OBJECT_REF" data="${checked_out[]obid[]}"/>
<!-- update happens here -->
<ie:param name="FIELD" data="IBA|<%= attributeName1 %>=<%= attributeValue1 %>"/>
<ie:param name="MODIFICATION" data="REPLACE"/>
<ie:param name="GROUP_OUT" data="retDoc"/>
</ie:webject>
Check In Objects Webject
- Check In the updated objects
<ie:webject name="CheckIn-Objects" type="ACT">
<ie:param name="type" data="WCTYPE|wt.doc.WTDocument"/>
<ie:param name="GROUP_IN" data="retDoc"/>
<ie:param name="GROUP_OUT" data="modified_documents"/>
</ie:webject>
Commit Transaction Webject
- Closes the transaction
<ie:webject name="Commit-Transaction" type="ACT">
</ie:webject>
// DOCUMENT CHECKIN AND CLOSURE COMPLETE - END THE SESSION
try{
End Session Webject
- Ends the session
<ie:webject name="End-Session" type="ACT">
</ie:webject>
}catch(Exception e){
String myExceptionMessage = e.getMessage();
The Error that I am getting when I try to run the process is:
Errors: wt.util.WTException: com.infoengine.util.IEException: Anonymous access to the session with id "gonb4rka;3448;150930" is not allowed. Nested exception is:
(wt.adapter.adapterResource/17) wt.util.WTException: Anonymous access to the session with id "gonb4rka;3448;150930" is not allowed.
Nested exception is: com.infoengine.util.IEException: Anonymous access to the session with id "gonb4rka;3448;150930" is not allowed. Nested exception is:
Nested exception is: wt.util.WTException: com.infoengine.util.IEException: Anonymous access to the session with id "gonb4rka;3448;150930" is not allowed.
and of course that repeats on and on. Does anybody have any clue what is causing this error to arise? Any help is greatly appreciated, thanks.
Try to groupout the session.
<ie:param name="GROUP_OUT" data="session"/>
How many method server is configured ?
