I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.0.1
We have a JNDI adaptor to allow us to login using our corporate Active Directory credentials. It has been working fine. Then our IT group imposed a password requirements of 20 characters minimum plus at least one special character, on the bind password for the adaptor. After making the change the Windchill method server will not start - see error below. What are the requirements of the bind password? Are special characters allowed?
Here are the errors that I faced
wt.system.err - javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C09050F, comment: AcceptSecurityContext error, data 775, v4563 ]
@VladimirN was right to provide article https://www.ptc.com/en/support/article/CS28129
From your error message...
"775" means the account is locked. Probably you entered the wrong password too many times and locked out the account. It needs to be unlocked before you can try again.
Articles:
Thanks for the response. I tried using escape character \ and also enclosing in single quotes per the article, but that did not help.
I also tried PTC’s SyntegraLDAPBrowser and LDAPSearch, and get the same Error Code 49.
Any other suggestions on what I can do to resolve?
First step is to confirm the credentials actually work. If LDAPSearch can't do it, Windchill won't be able to either.
Personally, I've never used Syntegra's LDAP Browser. I use Apache Directory Studio for LDAP validation. It leads you through the connection creation and ensures IT gave you the right information.
If you can't get past step 2, then IT gave you the wrong credentials information.
Once connected, you can browse the LDAP and...
You said the first issue is the Method Server won't start. That means the credentials in mapCredentials.txt have an issue. I set all my mapCredentials.txt entries at once. That way I am certain there are no remnants from a previous configuration.
xconfmanager -t codebase/WEB-INF/mapCredentials.txt -s mapcredentials.admin.adapters="{adapter name}^{bind DN, username, or email address},{bind password}" --add mapcredentials.admin.adapters="{adapter name}^{bind DN, username, or email address},{bind password}" --add mapcredentials.admin.adapters="{adapter name}^{bind DN, username, or email address},{bind password}"
If you have validated everything else and it still appears to be a special character, most US/UK keyboard special characters (e.g. !@#$%) work. The caret "^" is a problem for mapCredentials.txt.
https://www.ptc.com/en/support/article/CS387628
Escape characters for mapCredenitals.txt...
https://www.ptc.com/en/support/article/CS352881
International language special characters can also be problematic.
https://www.ptc.com/en/support/article/cs17326
Other password related documentation is in the knowledge hub...
https://www.ptc.com/en/support/article/CS374688
If your password includes carets "^" or foreign language special characters, tell IT to change the password again. There are plenty of other special characters on the keyboard that don't cause connection issues.
Just to follow up the issue has been resolved. It was the bind password was locked. Many thanks for all the replies and special thanks to mmeadows-3 for poining out "775" means the account is locked.
Thanks HelesicPetr
