I would like to change the process names of the various Windchill components so it is possible to differentiate between the FG and BG Methodserver process names, etc rather than having them all show up as Java.exe (ie Java_MS.exe Java_SM.exe and Java_BGMS.exe)
I have done it previously using the following properties in site.xconf:
But I get a load of warnings when I perform an xconfmanager -p:
operties instead
roperties instead
The only thread that I can see about this on PTCUser is not correct in my opinion as it loses all the command line options: http://portal.ptcuser.org/p/fo/st/topic=16&post=72171#p72171
Does anyone know the "Correct" way of performing the same thing so that xconfmanager -p does not complain and so that I do not lose any commandline options that are needed along with maintaining the configuration assistant tuning values?
Thanks in advance
Gary
With the help of Jess, and a little experimentation, adding the following properties to the site.xconf seems to do the trick with the least effort, whilst retaining the command line options:
<property name="wt.manager.cmd.MethodServer.java.cmd.quoted" overridable="true" targetfile="codebase/wt.properties"<br"/> value="C:\ptc\Java\jre\bin\java_MS.exe"/>
<property name="wt.manager.cmd.BackgroundMethodServer.java.cmd.quoted" overridable="true" targetfile="codebase/wt.properties"<br"/> value="C:\ptc\Java\jre\bin\java_BGMS.exe"/>
<property name="wt.manager.cmd.ServerManager.java.cmd.quoted" overridable="true" targetfile="codebase/wt.properties"<br"/> value="C:\ptc\Java\jre\bin\java_SM.exe"/>
This works on my Windchill 9.1 M060 System.
Rgds
Gary
