Hello everyone, how can I access through a JSP file to a database table. I am using MSSQL, at the moment I can refer to the table "EPMDocumentMaster" if I write <jca: describe Table var= "tableDescriptor" type= " wt.epm.EPMDocument" .
But I do not understand why the names are different, how to know the name type?
Error if I write the name as in the database:
No type can be discovered for descriptor: ComponentDescriptor [id="CustomMenubar" label="Part Table" summary="null" disableAction="null" mainType="null" configurableTableId="CustomMenubar" modelAttributes="null" properties="[menubarName:CustEx_table_menubar,saveInitialRows:false,actionModel:CustomToolbar,selectable:true,]" dataUtility="null" descriptorList="[ComponentDescriptor [id="classnamekeyroleAObjectRef" label="Название столбца" summary="null" disableAction="null" mainType="null" configurableTableId="null" modelAttributes="null" properties="[pdesc:CustomMenubar,sortable:true,ascending:true,dataStoreOnly:false,]" dataUtility="null" descriptorList="null" mode="null" type="null" tooltip="null" jsid="null"]]" mode="VIEW" type="TABLE" tooltip="null" jsid="null"] |
