When I Save As a WTPart with connected CAD objects and I select Re-use on the connected CAD objects they loose the connection to the new WTPart. I was expecting then to be carried forward. Does anyone know if there is a preference to ge the CAD objects ca
pmöllberg
Save As should carry forward releated CAD objects that have been set as Reuse.
Hi
there a misunderstanding about the "re use".  In save as , reuse just mean "re use the same child" if I Save as the assembly.
By default the Owner link between WTpart and CAD is 1-1 cardinality
Saving As the Wtpart will break the link. And you can't link the same CAD to différents WTparts
Since 10.2M030 PTC realeased the multi owner capability.  there's a special documentation to enable this feature.
One enable the behaviour will be:
If you save as a Wtpart and collect the CAD at the same time > give a new WTpart with a new associated CAD
If you save as a Wtpart without collect the CAD at the same time > give a new WTpart with the same associated CAD (ie multi owner link)
regards
