Wildfire 5.0 with PDMLink 9.0m30
lruocco
2-Explorer
Our current confirguration is Wildefire 4.0m050 with PDMLink 9.0M30. For testing purposes we installed Wildefire 5.0m30 on a machine and triedto register the server. It did not work. The compatability chart on PTC's website shows that this combination is not supported or invalid. So it appears that if we want to run Wildfire 5, we will have to upgrade to PDMLink 9.1. Does anyone know if there is a workaround or is anyone successfully running this combination using more recent builds?
Louis
avillanueva
23-Emerald I
(To:lruocco)
Unless you want to hear crickets from tech support, I would consider
upgrading to 9.1. It should be a relatively easy step up from 9.1.
There is no sense paying for tech support when, even if you found a work
around, they would not support that configuration.
