Windchill 10 - 2nd Installation Problem
borourke
11-Garnet
We had PDMLink 10(F000) installed on one of our test servers for evaluation purposes. An Oracle update caused some problems, so our DBA reinstalled Oracle and I am attempting to do the same with PDMLink. I uninstalled every thing I could through the Control Panel, and deleted the PTC directories. While running the Solutions Installer, I get a popup stating the Business Reporting is already installed and must be removed to continue. I know the obvious directories have been deleted, so is there some TEMP file or registry entry I need to delete? Thanks in advance!
Send lawyers, guns, and money...the sh!t has hit the fan!
rkalbhor
2-Explorer
(To:borourke)
In the User's profile 'Documents and settings' there is a .wt folder. Try
deleting it. Also check the registry any Cognos entry.
Rohan Kalbhor
MikeLockwood
22-Sapphire I
(To:borourke)
Cognos has its own Uninstall executable -which may have been removed now - this works well. Maybe this can be recovered from the recycle bin.
Many thanks to Rohan and Mike. I removed the .wt directory and Cognos entries in the registry and was able to proceed with the installation. Many thanks for your help and kindness!
