Hello everyone,
I have configured Windchill 9.1 M030 with Active Directory. I get the following error when starting the Method Server:
"Nested exception is: wt.util.WTException: javax.naming.AuthenticationNotSupportedException: [LDAP: error code 8 - 00002028: LdapErr: DSID-0C09018A, comment: The server requires binds to turn on integrity checking if SSL\TLS are not already active on the connection, data 0, vece ]"
My Google research has led me to the following: "ensure that the GPO (Group Policy Object) or local security setting "Domain controller: LDAP server signing requirements" is set to "None". I have confirmed that this setting is indeed set to "None". Does anyone have any other ideas as to what the problem could be?
Steve
