wt.system.err wcadmin - Nested exception is: wt.util.WTException: Rule configuration is invalid for rule wt.businessRules.BusinessRule
2016-07-24 15:20:41,881 INFO [RMI TCP Connection(151)-10.0.2.15] wt.system.err wcadmin - at wt.businessRules.ixb.forclasses.ExpImpForBusinessRule.preStoreValidate(ExpImpForBusinessRule.java:116)
2016-07-24 15:20:41,881 INFO [RMI TCP Connection(151)-10.0.2.15] wt.system.err wcadmin - at wt.businessRules.ixb.forclasses.ExpImpBusinessRuleCommon.storeObjects(ExpImpBusinessRuleCommon.java:47)
2016-07-24 15:20:41,898 INFO [RMI TCP Connection(151)-10.0.2.15] wt.system.err wcadmin - at wt.ixb.actor.PickingExistingObjectActorForPersistable.storeObjects(PickingExistingObjectActorForPersistable.java:184)
What are you trying to change that resulted in those errors appearing?
Give us some more information about the module, change, etc.
Also, what version of Windchill and build with CSP.
