Windchill Object Attribute Selection
jasonb13
7-Bedrock
I would like to have an attribute on a windchill object be assigned from a drop down list that is populated from an external database query. For instance I have a need to select a supplier to an object to assigna workflow variable; in this case I don't want to manage a supplier list, I just want to query my supplier database. Is this possible?
Nitin
7-Bedrock
(To:jasonb13)
You can create an adapter, then create IE task to query on database.
Then format the output group elements of this task to drop down values and use a data utility for rendering the component.
Sent from my iPad
On 05-Mar-2014, at 10:57 PM, "Jason Britton" <-<<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:-">>">mailto:->> wrote:
-----End Original Message-----
