Windchill services startup sequence
MikeFoster
All,
We've set up WindchillDS, Apache, Tomcat, and Windchill to run as services on a Windows 2008 server. We've found that if they don't start in that sequence when the server boots then the following irritating errors occur:
Error in Pricipal Administrator:
nullnull: [LDAP: error code 34 - The provided value "nullnull" could not be parsed as a valid distinguished name because the last non-space character was part of the attribute name 'nullnull']
Error in searches:
Server Exception: (com.infoengine.util.IEResource/..) com.infoengine.au.NoSuchServiceException: No Such service: .com.atk.ca..sv-apptest..Windchill
To correct this we had to specify the startup order for those services using the technique suggested in Microsoft's knowledge base article 193888.
Mike Foster
ATK
0 REPLIES 0
